barad_dur Posted November 5, 2009 Share Posted November 5, 2009 Howdy all, I have been working in H10, moving over from H9. My current build on 10 is 430. Everytime I select nodes and turn them into a subnet I lose everything. The second I shift + c, say like a tube node, the tube in the viewport dissapears (display flag on the new subnet is on) and when I dive inside the subnet all I see are the inputs. Further, when I convert the SN to a DA I get none of the associated parameters from the original tube node available in the edit parameter interface. Do I have something set wrong in H10 that I don't know about? I am including the hip file. Any advice would be helpful. Thank you. David Quote Link to comment Share on other sites More sharing options...
barad_dur Posted November 5, 2009 Author Share Posted November 5, 2009 Howdy all, I have been working in H10, moving over from H9. My current build on 10 is 430. Everytime I select nodes and turn them into a subnet I lose everything. The second I shift + c, say like a tube node, the tube in the viewport dissapears (display flag on the new subnet is on) and when I dive inside the subnet all I see are the inputs. Further, when I convert the SN to a DA I get none of the associated parameters from the original tube node available in the edit parameter interface. Do I have something set wrong in H10 that I don't know about? I am including the hip file. Any advice would be helpful. Thank you. David DA_Funk.hipnc Quote Link to comment Share on other sites More sharing options...
