Max to Houdini and back again
chadw
First of all a big Hello as I am new here.
I have a few questions about general workflow for Max to Houdini
1. Units in Houdini seem to be disregarded.... although I change my units in my hip file options, to mm from m, the scale of my objects imported as fbx is always the same. What gives?
2. Once in Houdini what is the best step to parent objects in one geometry node to another? I have an imported object as refrence which I would like to parent a metaball too in order to use the ripple solver, however I only want to parent my metaball and not my grid, so a fetch does not seem to work.
3. Once i get everything solved, what are people using to get their simulations back into Max.
Thanks for the help and advice.
