Procedural Volume Shader
gustav
Hi.
I want to create a procedural cloud inside a volume.
My idea is to use a function something like this:
if( (voxelPosition + noise(voxelPosition)) < 0.5 )
density = 1;
else
density = 0;
I figure I want create a Volume SOP that a connect to a Volume VOP, but I can't get it to work. Is this the right way of doing it?
Thanks!
Edited by gustav
Take a look at an isosurface node (with volume generation enabled - it generates surfaces by default). The variables $X, $Y, $Z are your voxel position.
Hi.
density = 1;
else
density = 0;
Thanks!
Thanks Peter, works great! I also found your video tutorials on volumes on vimeo, exelent resource on houdini. Thanks again.
Edited by gustav
