Muscle SOP and ObjectMerge question
ghang
hi , i having 2 GEO with objectmerge SOP inside the node connect to the Muscle SOP, but there is something probelm that was i need to choose Transform parameter as "Into This Object" then what happen is, the Muscle SOP recognize the Tx Ty Tz in 0,0,0.
but if i switch the parameter in ObjectMerge to "Into Specific Object", then everything work fine.
but that's the probelm, i need to use "Into This Object" to make the object transform refer to another GEO.
what can I do ?
thanks
