Cluster This Velocity Motion Blur
Hi Mark,
I am getting the chance to play with this tool, and am getting some great results! The speed, and memory hits are quite low, and we are able to turn around a lot of Geometry in a short amount of time.
At the moment, we are trying to get the Velocity Blur to with the File option, and aren't having much luck. It seems that the velocity attribute is being picked up from the File, and not the 'Parent' Points. This, of coarse, means that there's no way for motion blur to follow the direction that the particles (Parent Points) are moving.
Though, if I put 'v' on the File. Then the motion Blur defenitely shows up. Am I missing something?
I've attached a file, with what I hoped would be the proper setup for motion blurring instances...
Thanks again for the great tool, and I look forward to seeing it progress further, and further!
I am using cluster 1.4.7 compiled for H 10.0.369
cheers,
-j
ClusterThis_v0002.hip
