Fluid scaling
JaydenDP
Hi Guys,
I have a slight problem with my fluid smoke simulation, in that the effect I've been messing with so far is working well, but turns out, the scale of the scene I'm going to be getting to implement this effect into...is MUCH smaller! I could just scale the autodopnet, but the problem is that a lot of the effect relies on whats in and around the actual final scene for simulation.
Soooo, does anyone know of a good way to scale the fluid stuff while maintaining all the values that make the sim work at the original scale? i.e. if i resize the fluid container, emitter and stuff, the fluid wont react right because I tweaked the setting at the wrong scale!
Hope I'm getting my question across?
Thanks in advance for any help you can give
Thanks
Jay
Edited by JaydenDP
I had some similar scaling problem earlier.
I`m new to Houdini, but I guess you have to
get out everything you want to render from
DOP context to geometry context. You probably
use some DOP I/O or DOP import nodes.
If so, after having the simulation done,
you easily can scale the object which
contains the stuff from the simulation
you want to render. It doesn`t affect
the simulation.
You can continue to work with the scale
you want, and correct the scale at the end
of the network.
If you use objects for collisions or emitting,
and the objects are at wrong scale you can scale
them too in a separate geo object to your
simulation scale before using them in the dop network.
