ghang Posted December 10, 2009 Share Posted December 10, 2009 how to make an object just display as wire. (PS the object is not going to render just act as a CONTROL HANDLE, so i don;t want the object to display the surface just the line) Quote Link to comment Share on other sites More sharing options...
cellchuk Posted December 10, 2009 Share Posted December 10, 2009 wireframe sop? Quote Link to comment Share on other sites More sharing options...
pclaes Posted December 15, 2009 Share Posted December 15, 2009 for polygonal geometry you can use an "ends sop" with the "close u" set to "unroll" or you can use a primitive sop and in the face/hull tab you have the same options (I would use the ends sop as it is probably faster - less if statements to evaluate). Quote Link to comment Share on other sites More sharing options...
