Makefile .dll MinGW problem
Hi!
I'm new to this HDK thing, and I'm trying to compile a school laboration at home. At school we run Ubuntu and everything works fine, but I want to work at home for the upcoming project, and I'm running Windows 7 at home, so I need to make things work.
I'm running Houdini 10, with Visual Studio 2005 (8), as I've heard should be the one to use.
So I want to use Makefiles instead of "hcustom" to be able to use libraries from other files and so on. But I can't get the Makefile I use at school to work at home, please help me with this problem :]
This is the makefile I use in school (Makefile.VEXOP):
#Set OPTIMIZER to override the optimization level (defaults to -O2)
#Set INCDIRS to specify any additional include directories.
#Set LIBDIRS to specify any addition library include directories
#Set SOURCES to list all .C files required to build the DSO or App
#Set DSONAME to the name of the desired output DSO file (if applicable)
#Set APPNAME to the name of the desires output application (if applicable)
SOURCES = lib/RigidMultifractal.cpp vexop/VEX_Op_RigidMultifractal.cpp
    DSONAME = VexRigidMultifractal.so
    LIBDIRS = -L $(DRWLIBS)/lib -lpthread -lm
    INCDIRS = -I.
ifeq ($(OS), Windows_NT)
ifndef OPTIMIZER
    OPTIMIZER = -Ox
endif
include $(HFS)/toolkit/makefiles/Makefile.win
else
include $(HFS)/toolkit/makefiles/Makefile.linux
endif
OBJECTS = $(SOURCES:.cpp=.o)
ifdef DSONAME
TAGINFO = $(shell (echo -n "Compiled on:" `date`"\n         by:" `whoami`@`hostname`"\n$(SESI_TAGINFO)") | sesitag -m)
%.o:		%.cpp
	$(CC) $(OBJFLAGS) -DMAKING_DSO $(TAGINFO) $< $(OBJOUTPUT)$@
$(DSONAME):	$(OBJECTS)
	$(LINK) $(SHAREDFLAG) $(OBJECTS) $(DSOFLAGS) $(DSOOUTPUT)$@
else
%.o:		%.cpp
	$(CC) $(OBJFLAGS) $< $(OBJOUTPUT)$@
$(APPNAME):	$(OBJECTS)
	$(LINK) $(OBJECTS) $(SAFLAGS) $(SAOUTPUT)$@
endif
default:	$(DSONAME) $(APPNAME)
clean:
	rm -f $(OBJECTS) $(APPNAME) $(DSONAME)
install:
	cp $(DSONAME) ~/houdini10.0/dso/$(DSONAME)
At home I have MinGW installed, and when running
C:\MinGW\bin\mingw32-make.exe -f Makefile.VEXOP
in the houdinig command line prompt, with MSVCDir linked and so on (I can compile example files like SOP_Star.C), the follow error occurs:
LINK : warning LNK4044: unrecognized option '/L'; ignored
LINK : warning LNK4044: unrecognized option '/lib'; ignored
LINK : warning LNK4044: unrecognized option '/lpthread'; ignored
LINK : warning LNK4044: unrecognized option '/lm'; ignored
lib/RigidMultifractal.o : fatal error LNK1107: invalid or corrupt file: cannot read at 0x1110
mingw32-make: *** [VexRigidMultifractal.so] Error 1107
Is it possible to be able to work from home, or am I doomed? =)
I really want to get this to work really soon, thanks in advance!
I will upload the code that works in school, that compiles a .so-file.
(I have tried to change in the makefile to .dll and tried some various things, but with no success at all).
stuff.rar
