bing Posted December 31, 2009 Share Posted December 31, 2009 I following the example of VOP_Switch.C provided by sidefx and created my own vop node. My own vop node could read more than one images paths and export them at the same time . I have finished the vop but have some problems, which are small but annoying . first , i create unordered inputs which are used to read the images paths. Those inputs don't have corresponding PRM_Templates. When hitting "create parameter" for those inputs , the parameter would be set as "string" , not "image". I want to know how i could let the vop know it need to create a "image" type for the inputs. Second thing would be more worse. I add an function "maxOutputs()const" to let the vop have the ability to export more than one outputs at the same time. It works great. But after i saved the file and reopen the file, all the connection between those inputs and output parameter are broken. I don't know how it happened. Everything else just works perfect. Can anybody help to resolve those problems? Quote Link to comment Share on other sites More sharing options...
