Snap technique
I am coming from Maya and I start to learning Houdini and I like it:)
I have one problem and don't know how to do that in H. in Maya it is very simple. For example I have cylinder and I wish to place null/bone in place that is center of selected vertex's. In Maya I select row of vertex than I apply cluster and I get a perfection center of selected vertexes. Than I easily snap null/bone to cluster.
How can I do this in Houdini?
thanks
Create a null object and type the following expressions in its transalate X,Y and Z field centroid("../Yourobject", D_X), centroid("../Yourobject", D_Y) and centroid("../Yourobject", D_Z)
to align your null with the object you want and use snap option on the left side tool bar, to snap your bone with null object on bone creation.
If your using this funtionality quite often I would suggest, do the same thing with hscript or python and have it available in your shell so it will work on a button click as in maya.
Cheers,
Junaid
