Mixing fluids shader
WestFx
I have two fluids mixing into a third. Using the gas solver. Everything works great. However the basic liquid shader is applied to the particle fluid node. When rendered both fluids are the same with no color information applied. (both look like water). Is there a way to add a second shader to this simulation? Thanks!
