Import attribute problem
vbk!!!
Hello,
I can't import attribute I created in VOPSOP node.
When i check in the detail view I can see the value of my attribute but when I use importAttribute node in the VOPSOP nothing happen except for the first point of the object I want to "change".
I atached a example scene
It seems only the first point of grid object is affected by my VOPSOP ....
why my attrbiute react with only the first poin of my an object.
I use it as pivot reference ...
I don't know what I miss
Thanks for your help
importAttrib.hip
