Open Sound Control. Has anyone installed this plugin?
Hi
I'm trying to install (to comзile) the plugin houdini-osc.EARLYRELEASE.tar.gz , but have not yet obtained.
My sytem Mac OSX 10.5.6/XCode 3.1.4, and I tried on another system Mac OSX 10.6.2 the same
So I have:
bash-3.2# ./build.sh
The Houdini 10.0.528 environment has been initialized.
rm: dist/run: No such file or directory
//// echo ---- hcustom -i ../dist -I../include -L../lib -lpthread -loscpack -g CHOP_OpenSoundControl.cpp
Install directory = '/dist'
Linking with 'libpthread'
Linking with 'liboscpack'
Making debug version
Making directory /dist
Making CHOP_OpenSoundControl.o and /dist/CHOP_OpenSoundControl.dylib from CHOP_OpenSoundControl.cpp
cc1plus: warning: command line option "-fobjc-gc-only" is valid for ObjC/ObjC++ but not for C++
../include/oscpack/osc/OscException.h: In copy constructor 'osc::Exception::Exception(const osc::Exception&)':
../include/oscpack/osc/OscException.h:42: warning: base class 'class std::exception' should be explicitly initialized in the copy constructor
CHOP_OpenSoundControl.cpp: In member function 'virtual float CHOP_OpenSoundControl::getVariableValue(int, int)':
CHOP_OpenSoundControl.cpp:252: error: no matching function for call to 'CHOP_OpenSoundControl::getVariableValue(int&)'
/Library/Frameworks/Houdini.framework/Versions/10.0.528/Resources/toolkit/include/OP/OP_Parameters.h:166: note: candidates are: virtual float OP_Parameters::getVariableValue(int, int)
CHOP_OpenSoundControl.cpp: In static member function 'static void* OSCListenerThread::_thread_proc(void*)':CHOP_OpenSoundControl.cpp:277: warning: control reaches end of non-void function
Compile failed
I wonder what the reason is: some other type of the compiler's version, or something else
Thank you, I hope to support
Edited by dmitry evstropov
