Voronoi Export for liquid container
WestFx
Hello!
Kind of new here. For the past few weeks I have been messing around with Voronoi. Great tool! In short, I am filling a glass object with particles. The glass shatters and fluid goes every where. Fairly simple. The fracture to my object is happening in the dop network along with the fluids. When I run the simulation, A fatal error pops up. I have attempted a file sim export. Also a Rop export (Out>geo then sop path is connected to the dop of the glass geo)exported as a bgeo sequence. That works when the fracture is not on. When turned on and re simulated at the frame of impact the object is set to the original position.
So in short is there any way to export the fracture sequence to be called back into a dop sim as a rb ojbect to interact with the fluids?
If needed i can put a example together.
Thank you in advance for the help!
West
