Guest xionmark Posted June 20, 2003 Share Posted June 20, 2003 Hi, The Csound Score generator CHOP and File Out CHOP are now available in Linux flavor. And little endianism is now implemented for both Windows and Linux versions if the File Out CHOP. I discovered a flaw in the File Out format string parsing, mainly when trying output hex formatted numbers, so I'll soon have the string parsed out correctly rather then passing it in "as is". That way you'll be able to use channel expressions too. Here's the URL's: The CSound Score Generator CHOP: http://digitalcinemaarts.com/dev/csound/ The File Out CHOP: http://digitalcinemaarts.com/dev/file_out/ --Mark Quote Link to comment Share on other sites More sharing options...
