ikarus Posted February 20, 2010 Share Posted February 20, 2010 Okay so im setting up a simulation involving an imported mesh box with cuts that will be torn via an RBD object exiting the box (with initial velocity set), the box is a cloth object with tearing enabled, etc. The scene is pretty simple but when i try to simulate the scene i get an error message from the cloth solver saying "cannot retrieve data from previous solver" , i tried rearranging the merge node inputs but it either gave me the same result or did nothing at all. i havent been able to find anything online about this "previous solver retrieval" error. im attaching a screencap of the scene/network and the node thats giving the error. im running build243 if that helps at all. thanks Quote Link to comment Share on other sites More sharing options...
sam.h Posted February 20, 2010 Share Posted February 20, 2010 I had a problem with the cloth solver in 249.3, it would error whenever it collided or something ... try getting a later build. Quote Link to comment Share on other sites More sharing options...
