3DVFX Posted February 21, 2010 Share Posted February 21, 2010 Hi, How can select edge rings, or alternate edges in polygon mesh objects. Any short cut..? Quote Link to comment Share on other sites More sharing options...
mightcouldb1 Posted February 21, 2010 Share Posted February 21, 2010 L or shift L. There is a list of shortcuts if you look through the help docs. Quote Link to comment Share on other sites More sharing options...
Richey Posted February 21, 2010 Share Posted February 21, 2010 Hi, and is it possible to select more than one edge loop? When I select more than one edge and hit Shift + L I only get an edge loop of the last selected edge. Thx! Quote Link to comment Share on other sites More sharing options...
sadhu Posted February 23, 2010 Share Posted February 23, 2010 Hi, and is it possible to select more than one edge loop? When I select more than one edge and hit Shift + L I only get an edge loop of the last selected edge. Thx! Hi, one option is select an edge, press L. Then press shift + select another edge and again press L. I have got a question, If I want to select edges as seen in the attached image, is there any shortcut? edge loop.bmp Quote Link to comment Share on other sites More sharing options...
jim c Posted March 1, 2010 Share Posted March 1, 2010 If I want to select edges as seen in the attached image, is there any shortcut? Not all at once, you've got to add them to the selection set manually. It would be nice to be able to do this. It's probably also possible to write some sort of script that might do this as well. Quote Link to comment Share on other sites More sharing options...
