Moving a particle over a poly shape
jfhtx
I'm rather new with Houdini but I just try to achieve one thing with paticles.
I saw different post with sliding,creeping,cling,prim,primuvu,..ect for moving a particle over a surface.
I tried all those things on a low poly human shape and it works but the motion of the particle is random over the surface.
So my question is :
is it possible to move one particle all over a surface in a smooth way so I can simulate with the trail surface node a kind of wollen wire shape?
I tried to use the Position particle node but with different functions like sin and cos...but it doesn't work.
Any light to help me ?
thank you
Thank you Jason for the tip.
I tried with sdf and it was not better than the solution I found with different post to slide particle over a polygon shape.
I have a source->create posprim->create posuv->creep->drag->property for cling.
As you see the outcoming is quite what I was looking for.
But I would like to move the particles in a less random way
because some time the particle seems to stay in one place and don't move far away from that place.
I would like to position the particle and to find a way,so that particle will go all over the shape.
Edited by jfhtx
See attached.
Only works if target geometry has gapless, non-overlapping UVs.
Spanning isn't handled in this file; Its where the lack of procedural
edge grouping (including curve segments) starts to hurt.
Hi
I'm working on your great hip,it is I think what I'm looking for.
thank you.
