dop sim every frame
skydave
I have a dop which simulates something and the result of that dop is used at another place in my setup.
Now what I want to do is to run the full dop simulation every frame.
like this:
frame 1.: initialise and then run the dop for 10 frames -> take end result and do something
frame 2.: initialise and then run the dop for 10 frames -> take end result and do something
frame 3.: initialise and then run the dop for 10 frames -> take end result and do something
frame 4.: initialise and then run the dop for 10 frames -> take end result and do something
etc.
so basicly what I need is a dop node which will run a solver multiple times per frame.
I tried to play around with substeps but I didnt get it to work. Could it be achieved by this?
I also looked at the wedge rop but since there will be other animated stuff in the scene this is not exactly what I want. I would have to bake all animated stuff out and then have it as a input depending on wedge iteration.
Any ideas anyone?
David
