3Delight OSX
Can somone post a step by step instruction to setup 3Delight and Houdini 10 OSX?
I setup the houdini.env with HOUDINI_DEFAULT_RIB_RENDERER = "3Delight9.0".
Set the HOUDINI_VIEW_RMAN=renderdl. Install the display-driver via proto_install.
The renderman.ini where also modified. I can write a rib file but the display don't work.
Please can somebody help me!!
