Render Single Plane?
I know how to split render output into different planes (or passes if you want).
Does anyone know how to render single pass(vex variable) and not bother with other calculations(other vex variables)?
I think that one way could be to write special shader that can disable the rest of passes you don't need. But there is few limitations/disadventeges as far as I can see:
1. It won't block the calculations you dont need, it won't just show them in render output, right?
2. It is "per shader"/"per object" solution so it could be quite tricky to set them in complicated scenes the way you want.
Any thoughts or suggestions are welcome.
