normalized inverse square...
In order to normalize something to a 0-1 range you have to take the max value and use that as the divisor.
This thread may be useful to you:
You can also use the fit expressions
if you type "exhelp fit" in the hscript textport, you will see some examples. You will probably be using fit01 in which case you will need to specify min and max values to be remapped to a 0-1 range.
Edited by mightcouldb1
It depends on what you really want. If by "normalization" you mean "fitting into 0-1 range" then you can divide by maximum of that whole expression you wrote (but careful, in another expression you may get negative numbers). Or, use the fit expression. In both cases you may need to find the min and max values either via a network ( with attribute promote) or a small python script. One problem here could be freak values that give you bad results, especially with particles. In that case you may need a clamp as well.
If you however you are after the normalized vector, or a component of a normalized vector, then you should do that on an expression having $V and not $VY (and don't divide the vector by a number!)
Edited by Macha
The expression 1/(x2+1) will always have a [0,1] range for every real-valued scalar x, so I think in this case, interpreting "normalization" as the requirement that the result be in the [0,1] range is not the issue (as this will automagically happen by itself).
I believe the confusion here comes from trying to apply this quadratic variation on the inverse square law to a directional vector (velocity). That, I'm afraid, doesn't make much sense.
Need a better explanation of what the OP is trying to do, I think.
Absolutely right. And I should explain because I think I just set everyone off on a wild goose chase. My apologies.
I have a sim animating straight up and then falling down to the surface. The sim has already been cooked and so I'm only putting some additional pscale onto the particles.... So anyhew, at it's peak height, the particles need to be a bit larger than the rest of the particles so that when I mesh using the "Particle Fluid Surface" sop I get a smooth increase in scale based on taking the inverse square of $VY. (It works just fine as is and I moved on). But that night, at some point I felt it necessary to include $VX and $VZ so that I could possibly prevent any unwanted visual artifacts. I suppose I was thinking of something like using the length expression but somehow translating that to normalize?... What? Wow I can't even imagine at this point. Next time I need to re-visit this perhaps I'll do something like evaluating the length($VX,$VY,$VZ) first and then adding the inverse square...
thanks everyone.
