Circle Path/Turntable w/o Keyframe
I posted this on the Sidefx forum but I am also asking here. I am interested in creating a 360 degree circle path for a camera turntable or just basic spinning is there a way to do this without using keyframes as in the Digital Tutors tutorial?
DJ
Old School: $T in the position for the object is exactly what I was looking for. With just
$T
or $T*n where n is any number to slow it down is what I used to see what else could work. On the Side Effects forum I was given another solution where you parent your object (or your camera) to a null and put $FF in the y rotation of the null.
use
fit($FF,1,240,0,360) to rotate 360 degrees over 240 frames.
DJ
