why dose not my VEX SOP node work ?
It´s working fine, it returns the Y position based on the sin function, but I think you want to combine both sin waves, to do that you´d have to modify the VEX so that it adds the result of the function to the actual position, to get this behaviour just add an Add node, and pipe to it P from the global variables, and the result of floattovec1, the output of the Add should go to P on the output.
Edited by pencha
