Glowing particles
Dageris
look great, i am messing around too, can you share me how you render the particle ?
Thanks! Sure heres how i rendered them. To get the rainbow like color on the particles i put a color node in the popnet. Inside the color node i changed the color setting to $BBX $BBY $BBZ. To get them to glow i just added the glow material to the particle node in the object view. Oh make sure to turn on enable emission in the glow material. Hope that helps!
Thanks so much :), hope to see more effect from you.
Very nice for just playing around. Im doing a simualar project. How did you get the ribbon motion of the particle of the explosion?
Thanks! To get that ribbon motion I added noise in the gravity node. The force is 1 in the Y axis so it pushes the particles upward and the scale is at 3. In the noise tab the amplitude is 10 10 0 :)
