How to create a LUT in Houdini?
Howdy,
I have been playing around with the Color Settings in the Edit menu in order to cater to a Linear Workflow (yes, I know I am a bit late to the party ;)).
There is one entry for a LUT file and the Houdini Help says about that that you can plug a LUT file in there that you create in Houdini itself by right clicking any Color COP node and choosing Save LUT... from there.
I am trying to create a simple 1D LUT following the well known sRGB formula (see end of message) and I tried laying together pow and other math nodes in a COP filter VOP context but then I saw you can't right click a non Color COP and save it's processing to a LUT - the Save LUT... command will fail saying it can't be done.
So how can I make an sRGB LUT from VOPs?
Thanks for reading!
André
sRGB response curve
if (in <= 0.00304)
    out = in*12.92;
else
    out = (1.055 * pow(in, (1.0/2.4)) - 0.055);
Ok, been playing around a bit more and this is what I got.
There is a Color COP node, LUT (doh), which lets you crossreference a CHOP node.
My guess is that I would be able to create a true sRGB response curve with CHOPs, then reference it with the LUT node, which I can right click and Save LUT...
Before I saw this, however, I simply exported Nuke's sRGB curve as ASCII, and pasted it's values in a Houdini .lut file I exported earlier.
In case anyone has a use for it, I'll attach it to this post.
FWIW, the LUT doesn't appear to work with the Render Region tool, but everywhere else it does.
Sorry for the double reply, forgot to press "Attach This File" and editing my previous post wouldn't let me attach the file again.
sRGB.lut.zip
Hello André,
thanks a lot for sharing! I ran into the same problem few days ago while creating a sRGB LUT file from COP nodes or VOP's.
Didn't recognize that the LookupCOP can reference CHOP's. Great! :)
Christian
