ziggx Posted May 8, 2010 Share Posted May 8, 2010 Hi there, I'm trying to apply a texture to a deforming particle fluid surface but the texture slips. In the help card it, tantalisingly, mentions generating a coordinate system which can be transferred to the fluid surface. I have a hunch this is what I need to do - unfortunately, there is no clue "how" I actually achieve this. Has anyone got any tips? TIA Ziggx Quote Link to comment Share on other sites More sharing options...
mightcouldb1 Posted May 8, 2010 Share Posted May 8, 2010 (edited) This might help: http://lulu1315.wordpress.com/2009/05/22/simulating-with-voxels/ There is a way to modify the particle fluid OTL to have UVs although it doesn't look great when the fluid starts to move around. Realflow seems to do a good job at maintaining its UVs. I'm curious for a solution as well. Edited May 8, 2010 by mightcouldb1 Quote Link to comment Share on other sites More sharing options...
ziggx Posted May 9, 2010 Author Share Posted May 9, 2010 Thanks for the link - it was very interesting - certainly shows what is possible - looks like more research required. Best Wishes Ziggx This might help: http://lulu1315.wordpress.com/2009/05/22/simulating-with-voxels/ There is a way to modify the particle fluid OTL to have UVs although it doesn't look great when the fluid starts to move around. Realflow seems to do a good job at maintaining its UVs. I'm curious for a solution as well. Quote Link to comment Share on other sites More sharing options...
