Akabane Posted May 10, 2010 Share Posted May 10, 2010 Yo there. I'm actually trying to shade some particles with a similar shading as the Mayas Cloud Particle shader. I thought that i would achieve that by copying some geometry to the particles (say, metaballs or spheres) and then shade those with a volumetric shader. But how do I use something like particle life to set colors etcetera? Something like the particle sampler info node in maya... So: which is the workflow for shading particles like a volumetric entity using particle attributes? Thanks! Quote Link to comment Share on other sites More sharing options...
pclaes Posted May 11, 2010 Share Posted May 11, 2010 download the fx shelf and have a look at the heavy smoke, that does pretty much what Maya cloud does, you can open up the asset and plug in your own particle system. The main thing that happens is a look up of the coordinate system to look up the noise applied to each metaball. Quote Link to comment Share on other sites More sharing options...
tomhanks Posted June 4, 2010 Share Posted June 4, 2010 Hi, Where Can I download this FX Shelf? Quote Link to comment Share on other sites More sharing options...
pclaes Posted June 4, 2010 Share Posted June 4, 2010 click on the little "plus" sign next to any of the shelf tabs and in the menu: download shelf Quote Link to comment Share on other sites More sharing options...
