aelzor Posted June 3, 2010 Share Posted June 3, 2010 Hi, New to the forums and pretty new to Houdini. I've been playing around and getting somewhat (in the limit of the time i've used houdini) acquainted with houdini. My aim now is to animate a moving elevator. The elevator will move up and down as usual, and whenever it makes a normal stops I want the wires that are attached to vibrate, kinda subtle.. I vibrating wave that passes through the wire and weakens by time. Any ideas about how I should go about to achieve this effect? Thanks. Quote Link to comment Share on other sites More sharing options...
Macha Posted June 4, 2010 Share Posted June 4, 2010 Not amazing, but it's one idea. wire.hipnc Quote Link to comment Share on other sites More sharing options...
Macha Posted June 4, 2010 Share Posted June 4, 2010 And here a DOP wire, but it is hard to control and tweak. wiredop.hipnc Quote Link to comment Share on other sites More sharing options...
Macha Posted June 4, 2010 Share Posted June 4, 2010 And here is yet another, easier to use method, just because the problem interest me. Quote Link to comment Share on other sites More sharing options...
Macha Posted June 4, 2010 Share Posted June 4, 2010 forgot to attach file... lift.hipnc Quote Link to comment Share on other sites More sharing options...
aelzor Posted June 8, 2010 Author Share Posted June 8, 2010 Hey, sorry for the late answer, had a lot of work to be done. Anyways, great examples. You seem to be on the same track as me, although I wanted more subtle/weaker vibrations.. I will try these out and work from there. Thanks! Quote Link to comment Share on other sites More sharing options...
Macha Posted June 9, 2010 Share Posted June 9, 2010 (edited) Hey, sorry for the late answer, had a lot of work to be done. Anyways, great examples. You seem to be on the same track as me, although I wanted more subtle/weaker vibrations.. I will try these out and work from there. Thanks! Just a quick idea that popped into my head now. How about doing a high frequency wave on the normals only. That could perhaps make a quick hifreq vibration-look during render (motionblur) Edit: velocity vectors, not normals. Edited June 9, 2010 by Macha Quote Link to comment Share on other sites More sharing options...
