ehsan parizi Posted June 19, 2010 Share Posted June 19, 2010 Well, this should be pretty easy, but I couldn't find a way to make my particles make trails, I tried trail node, but it connects all the particles to each other based on the particle numbers, I also tried to use connectivity and partition to make different groups out of each particle, but it doesn't work that way, it considers all the particles as one primitive. suggestions? thoughts? Quote Link to comment Share on other sites More sharing options...
efecto Posted June 20, 2010 Share Posted June 20, 2010 You can use 'split' node to emit particles from original particles. pTrailSplit.hipnc Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted June 20, 2010 Author Share Posted June 20, 2010 thanks. Quote Link to comment Share on other sites More sharing options...
Macha Posted June 21, 2010 Share Posted June 21, 2010 You can also use the trail SOP. You may need to adjust cache size. Quote Link to comment Share on other sites More sharing options...
