Cooking Python node every frame
Hello all,
How to make a custom python node time dependent, i mean to cook it every frame so that the value in the parameter gets updated every frame? i tried adding frame number to calculation but even that doesnt seems to do the trick?
Is there some function like setTimeDependent()?
I was browsing a bit about it and found that the following code will make the node to cook every frame.?
OP_Node::flags().timeDep = 1;
REF from: http://accad.osu.edu/~pete/Houdini/html/qa/index.html
If so, how to implement it in a python node.? Where should i write it.?
Edited by Homguy
Well looking at the SOP_HOMWave example evaluating the frame seems to cause it to be time dependent for me.
Alternatively you can use how you mentioned. The newer, more correct method would be to use OPNodeFlags::setTimeDep(1) in your cook function. To do this in an operator you'd do something like
this->flags().setTimeDep(1)
Edited by graham
Thanks a lot for such a quick reply graham. Should I add this in the code tab of the operator ( i mean the window that comes when we select Type Properties ).?
And the code should be something like this, right.?
node = hou.pwd()
node.setTimeDep(1)
If not, correct me please..?
Cheers.
I'm confused. Is this regular Python SOP or an operator written in the HDK using HOM? This is the HDK forum but now I believe you are just talking about a regular Python SOP operator.
If it's a regular Python SOP then all you need to do to force time dependency is throw this in the Python code somewhere in the Code tab of the Operator Type Properties. It will make sure the node is evaluated every frame.
f= hou.frame()
If it's an HDK op then you'll have to do what I mentioned above.
Oops.. Sorry graham.. I dint notice that im in HDK forum.. Mine is a regular Python SOP.
And, i already have hou.frame() in my code. But still the parameter is not updating every frame when i hit the play button( in the timeline ).
When i hit the stop button, then the parameter updates to the proper value. The full code is not with me right now. I will post the
code soon and then kindly help me solving it.
Once again, sorry for posting it in a wrong page.
Edited by Homguy
Turning on "Continuous parameter updates" option solved the issue. Thanks graham.
And this the code my python node has.
# This code is called when instances of this SOP cook.
geo = hou.pwd().geometry()
# Add code to modify the contents of geo.
#current node n its parameter
curr_node = hou.pwd()
ind = curr_node.parm("index")
t = curr_node.parm("test")
#another node n its parameters
bs = hou.node("../aboveNode")
num = bs.evalParm("aParameter")
#break value n frame value
brk = 1
f = hou.frame()
for n in range(num):
    if(brk == 1):
        v = bs.evalParm("blend" + str(n))
        if(v == 1.0):
            value = n+f-f    #added n sub the frame number to recook the node every frame. but not working
            ind.set(value)
            brk = 0
Although it has hou.frame() in it and on MMB click shows time dependent, it doesnt update the index parameter every frame. Is there anyway to make it update every frame without turning on Continuous parameter updates option.?
It's like that by design. When continuous updates are off, the UI doesn't need to be redrawn every frame as the animation plays so performance is improved at the cost of parameters not having their values displayed. Setting it on or off is just a UI thing and does not actually effect your nodes.
