fixed length curve, where to start
I'm wondering if someone could provide a sort of learning road map if I wanted to create a node that is similar to a fixed length curve in maya (you can pull on the last point, and all previous points will adjust to keep the curve at a fixed length). I have some programming/scripting knowledge, and only a little houdini knowledge. Perhaps this can even be created with a dops network, I don't know. I just want to be able to use it real time, interactively. We have a proprietary tool here at work for fur and the curves have locked length so its easy to edit groom (just grab the end and pull it around), I would just like to have the same tool in houdini. Anyways, I'd appreciate it if someone could tell me how they would tackle this project, thanks.
  • Downvote 1
The resample SOP can already do this. Give it 'max segment length' of const_hair_length/num_segs_in_hair, and a 'maximum segments' of num_segs_in_hair.
If you really wanted to roll your own, though, GU_Resample is your friend:
const unsigned constLength = 1;
// pre-pack array of prims since gu_resample modifies the gdp as we go.
UT_PtrArray<GEO_Primitive*> prims;
GEO_Primitive* prim;
FOR_ALL_PRIMITIVES(gdp, prim)
  prims.append(prim);
GU_Resample resampler;
resampler.setLength(constLength);
for(unsigned i = 0; i < prims.entries(); ++i)
  GEO_Primitive* const thisPrim = prims[i];
  GEO_PrimPoly* resampledPrim = resampler.resampleFace(dynamic_cast<GEO_PrimPoly*>(thisPrim)); // obviously you should make sure it really is a primpoly first...
  gdp->deletePrimitive(*thisPrim);
Rough, but something like that can achieve the same effect.
Edited by Vormav
