L-System Helix
bandini
Anyone know how to make a helix in L-Systems?
I can make one using some basic rules (below), but it is always off-axis, pointing in a strange direction.
Using:
FA
A-> +/FA
Just looking to make one that goes straight up.
Edited by bandini
It's very rough hack, but try this as your premise:
^(135)/(13)FA
Thanks, Macha, but changing the angle value will cause problems. I'm looking for a more generic solution where I can continue to play with angle, spacing, growth, etc.
It's trickier than I thought!
It's maybe not what you want but the following expression creates a customizable helix, but the problem is that it's presumably (for your purposes) connected wrongly. You could fix that afterwards though I guess. I'll keep digging and see if I come up with something better. I'm sure I did one of those in the past.
Premise A
A = [&(90)F(2) D]F(0.1)/(410)A
Ok, I had a moment to look at it, and this appears to be exact, with the option of tapering as well:
Premise: A(1)
Rule: A(s) = +(58)/(4.2)"(4*s)F(s)A(1*s)
Hey Macha,
Thanks for doing that. I don't think its exactly right, though. Look at it from the top view and play with some parameters. Still get's wonky or goes off axis.
Someone at work showed me a way to get a helix. I think it is still a bit of a hack, but it definitely works. It uses tropisim to get the spiral pointing the right way:
Premise: FA
Rule: A = /+FTA
Set gravity to -50.
I think it still is a bit of a hack though. Would be nice to know what the "correct" way of doing this is.
Edited by bandini
