upres particle cache
vectorheadsp
Hello
I have a particle cache that I imported into houdini, and was wondering if I can take that cache and cache it out again with a (random seed) to kinda up res it?
I read somewhere that a wedge node and a take may be able to do this, however I am not sure if this can be done with an existing cache.
Has anyone had to do this before? Your advice/approach would be helpful.
Thanks!
Not sure what you mean. I guess you have a bunch of animated points and want to add more of them?
One idea I have would be to find each particle's neighbour, draw a vector between them, scale it by half, and use that as your new position with all other attributes blended.
The problem here would be that a particle's nearest neighbor is not always another particle's nearest neighbor so there may be visual problems, or nor. It depends a bit on the scene.
A more basic version of this would be to just add a whole bunch or random points and attribute transfer the relevant attributes.
If it animates convincingly has to be tested.
Edited by Macha
possibly construct a voronoi cell grid from the existing point cloud and use a pc lookup to get velocity!
