Callback script for multiparm block
Unfortunately it is not possible to attach callback scripts to multiparm blocks. Here's a post with a more technical description and a possible suggestion.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=19221&highlight=
Also, you might be able to work something out now in Houdini 11 using the new per-node event callbacks and hou.nodeEventType.ParmTupleChanged but I'm not sure what kind of information that will give you in the case of a multiparm object changing.
http://www.sidefx.com/docs/houdini11.0/hom/hou/Node#addEventCallback
