non-english letters in font
Theis J
If you use the "\\" in the text parameter of the font SOP it will use ASCII code instead of what you write, so you have access to all characters.
i.e. you can type \\`33` and it will give you letter A which corresponds to code 33.
The first 31 non-printing characters are skipped, so you actualy have 93 instead of 127 characters.
I imagine you can only use this trick as long as the font you´re using does have the character you are after.
I learnt this from Craig´s Zerouini "Houdini on the spot". It´s a cool bag o´ tricks.
