luoqiulin Posted August 24, 2010 Share Posted August 24, 2010 my system is win7x64,when i start hqueueserver it stoped in seconds,and the hqueueserver page(localhost:5000) can't be opened.and there is the errorlog,i don't know what's mean,any help? Traceback (most recent call last): File "C:\HQueueServer\python26\Scripts\paster-script.py", line 8, in <module> load_entry_point('PasteScript==1.7.3', 'console_scripts', 'paster')() File "C:\HQueueServer\python26\lib\site-packages\pastescript-1.7.3-py2.6.egg\paste\script\command.py", line 84, in run invoke(command, command_name, options, args[1:]) File "C:\HQueueServer\python26\lib\site-packages\pastescript-1.7.3-py2.6.egg\paste\script\command.py", line 123, in invoke exit_code = runner.run(args) File "C:\HQueueServer\python26\lib\site-packages\pastescript-1.7.3-py2.6.egg\paste\script\command.py", line 218, in run result = self.command() File "C:\HQueueServer\python26\lib\site-packages\pastescript-1.7.3-py2.6.egg\paste\script\serve.py", line 276, in command relative_to=base, global_conf=vars) File "C:\HQueueServer\python26\lib\site-packages\pastescript-1.7.3-py2.6.egg\paste\script\serve.py", line 313, in loadapp **kw) File "C:\HQueueServer\python26\lib\site-packages\pastedeploy-1.3.2-py2.6.egg\paste\deploy\loadwsgi.py", line 204, in loadapp return loadobj(APP, uri, name=name, **kw) File "C:\HQueueServer\python26\lib\site-packages\pastedeploy-1.3.2-py2.6.egg\paste\deploy\loadwsgi.py", line 225, in loadobj return context.create() File "C:\HQueueServer\python26\lib\site-packages\pastedeploy-1.3.2-py2.6.egg\paste\deploy\loadwsgi.py", line 625, in create return self.object_type.invoke(self) File "C:\HQueueServer\python26\lib\site-packages\pastedeploy-1.3.2-py2.6.egg\paste\deploy\loadwsgi.py", line 110, in invoke return fix_call(context.object, context.global_conf, **context.local_conf) File "C:\HQueueServer\python26\lib\site-packages\pastedeploy-1.3.2-py2.6.egg\paste\deploy\util\fixtypeerror.py", line 57, in fix_call val = callable(*args, **kw) File "<stdin>", line 44, in make_app File "<stdin>", line 43, in load_environment File "<stdin>", line 25, in __init__ File "<stdin>", line 54, in __init__ File "<stdin>", line 129, in getServerConfigAsInt File "<stdin>", line 118, in getServerConfig File "<stdin>", line 923, in getServerConfig File "<stdin>", line 1590, in _executeQuery File "C:\HQueueServer\python26\lib\site-packages\sqlalchemy-0.5.1-py2.6.egg\sqlalchemy\orm\query.py", line 1164, in first ret = list(self[0:1]) File "C:\HQueueServer\python26\lib\site-packages\sqlalchemy-0.5.1-py2.6.egg\sqlalchemy\orm\query.py", line 1085, in __getitem__ return list(res) File "C:\HQueueServer\python26\lib\site-packages\sqlalchemy-0.5.1-py2.6.egg\sqlalchemy\orm\query.py", line 1225, in __iter__ return self._execute_and_instances(context) File "C:\HQueueServer\python26\lib\site-packages\sqlalchemy-0.5.1-py2.6.egg\sqlalchemy\orm\query.py", line 1228, in _execute_and_instances result = self.session.execute(querycontext.statement, params=self._params, mapper=self._mapper_zero_or_none()) File "C:\HQueueServer\python26\lib\site-packages\sqlalchemy-0.5.1-py2.6.egg\sqlalchemy\orm\session.py", line 755, in execute clause, params or {}) File "C:\HQueueServer\python26\lib\site-packages\sqlalchemy-0.5.1-py2.6.egg\sqlalchemy\engine\base.py", line 824, in execute return Connection.executors[c](self, object, multiparams, params) File "C:\HQueueServer\python26\lib\site-packages\sqlalchemy-0.5.1-py2.6.egg\sqlalchemy\engine\base.py", line 874, in _execute_clauseelement return self.__execute_context(context) File "C:\HQueueServer\python26\lib\site-packages\sqlalchemy-0.5.1-py2.6.egg\sqlalchemy\engine\base.py", line 896, in __execute_context self._cursor_execute(context.cursor, context.statement, context.parameters[0], context=context) File "C:\HQueueServer\python26\lib\site-packages\sqlalchemy-0.5.1-py2.6.egg\sqlalchemy\engine\base.py", line 950, in _cursor_execute self._handle_dbapi_exception(e, statement, parameters, cursor, context) File "C:\HQueueServer\python26\lib\site-packages\sqlalchemy-0.5.1-py2.6.egg\sqlalchemy\engine\base.py", line 931, in _handle_dbapi_exception raise exc.DBAPIError.instance(statement, parameters, e, connection_invalidated=is_disconnect) sqlalchemy.exc.OperationalError: (OperationalError) no such table: config u'SELECT config.id AS config_id, config."clientId" AS "config_clientId", config.name AS config_name, config.value AS config_value, config.mtime AS config_mtime \nFROM config \nWHERE config."clientId" IS NULL AND config.name = ? \n LIMIT 1 OFFSET 0' ['activeTimeout'] Quote Link to comment Share on other sites More sharing options...
