scattering static points on moving volume with static noise
JoshJ
I have a camera frustum based volume, and I have it set up so that the camera can move through the scene while noise that's being multiplied in the volume stays static in world space. That's working very well.
Now I want to scatter points onto the volume and I'd like those points to stay static in world space also. However, when I use the scatter sop to do this, the points are rescattered every frame since the volume changes, so it appears that the point positions change. Any ideas on how I could keep the points static throughout the animation, while having them be dynamically created and removed when outside of the volume bounds?
I've already ruled out creating the points beforehand then culling them, as I need to create a massive amount of points, so this really needs to be some kind of dynamic process that updates itself throughout the animation.
I think you can't really get around making the points first and culling them afterward.
Rather than a ray sop I would use a lookup in a vopsop against an SDF/volume sample.
What I tend to do in such a case is split your volume in subvolumes and do the culling in separate chunks on the farm.
If you are using it to go straight to rendering, you could do it as a custom VRAYprocedural.
Perhaps you could assign a point position by feeding a random generating function with an attribute. Something like setting the P attribute to rand($PT), rand($PT*2), rand($PT*3). That way each point would have a unique random position.
BTW, how many points are we talking about? Grouping/deleting by sdf volumes is very fast.
Edited by Macha
It is, because it is as a vopsop, the part that is slow is the sdf generation though. And as he stated it is required at every frame. Still you could generate several highly detailed sequences of sdf in paralell if you have multiple cores you could run them in the background - once cached to disk they should be a lot faster. If it is just one sequence, better not compress them as that makes it slower.
Thanks for all your suggestions guys... I ended up generating the points in cubes of like 25 to 50 square units, based on the distance from the camera's path... testing the distance from the camera and whether it will be in view, then writing them out to disk, then another set of nodes to read it back in and cull the area I want based on the camera's position. I wanted to generate them based on some particular vop sop noise that I already had in the frustum volume. Total amount of points would probably be 100 million or so, maybe more depending on the distance the camera has to travel (which was yet undetermined)... so I wanted to figure out some way to break it up and have a nice procedural system convenient for scaling up...
I am really interested in the custom VRAY procedural approach... just haven't had time to look into it, if there's any tips/direction you can point me to, I'd highly appreciate it.
Edited by joshjordan
keep an eye on this: http://www.peterclaes.be/blog/
I'm going to be updating it soon. At the moment just basic info, but I managed to get up to 160 million polygons rendering with my custom instancer. In other versions I have built in pointcloud and Level of Detail support. But don't expect anything complete very soon, I want to share information properly, step by step and thoroughly. That does take a bit of time. I will try and put the source code of my instancer online with the next posts. That way you can go through it yourself if you want to have a look at some of it.
  • 3 years later...
hey there,
So I came across this post while having a similar problem.  Geometry into Vopsop, displace with noise  then animate.  Attached another vopsop for some color noise then used a scatter to copy some spheres onto the deforming geo.   I'm noticing my scatter points jumping all around.  I would like them to stay static so I could animate the noise within the vopsop to move them around.
Not quite a newbie to Houdini, but not understanding the above solutions, if they are correct for my issue.
Thanks
Edited by cowboy71
