simple questions for vex
wes
from the docs:
L: The vector from the point on the surface to the light
source. The length of this vector represents the distance
to the light source.
Initialization of the L Variable
In the Light and Shadow contexts, the P variable represents the
position of the light source and the Ps variable represents the
position of the surface point being shaded.
In Houdini, lights can have either perspective or orthographic
projections. An orthographic light in Houdini is used to represent an
infinite (or very distant) light source which has all the light rays
parallel with each other. A perspective light acts more as a point
light source.
When a perspective light shader runs, the L variable is
initialized as follows:
L = P - Ps; Orthographic lights, on the other hand, are initialized so that the
direction of L is the same for each light ray eminating from the light
source.
L = Lz * dot(Lz, P - Ps); Where Lz represents the normalized "z-axis" of the light source
(i.e. a unit vector pointing down the z-axis in the space of the
light). Thus, the scale of the L variable will be the orthographic
distance from the plane of the light source and the surface point
being shaded.
In a light shader, it is possible to change the L variable to any
value you choose. However, this is how the L variable is initialized.
thanks, anakin78z...
L is from Ps to P, it's true for surface, displacement, fog,...I get confused because for photon context, L is from light position to the surface point, and in renderman, L is from P to Ps for light shaders. So, I wanna make sure if L is from Ps to P or P to Ps in vex light & shadow contexts.
Can someone give an direct answer?
Thanks in advance.
