burningfuses Posted September 16, 2010 Share Posted September 16, 2010 Hello, I want to connect Ableton Live! to Houdini and I thought the easier way would be to use the MIDI in CHOP. The problem is that after creating the node in Houdini, the only option at the "MIDI source" is "MIDI File". According to Houdini's documentation I should have 3 options: "hardware port, internal, file". I believe that the option that I need is "internal", but it is not available. What am I missing here? I'm running Houdini 11 (Apprentice). Thank you. Quote Link to comment Share on other sites More sharing options...
