carl Posted September 30, 2010 Share Posted September 30, 2010 Hello, I'm trying to open a scene that was made with houdini build 11.503 with build 11.469(official build). The problem is 469 is closing with Fatal error: Segmentation Fault error whenever I try to open the hip file. The reason I'm trying to use 469 is because of realflow plugin as it was build for that version and doesn't work with build 503 or I assume anything above 469. Is there anything I can do to fix this? Quote Link to comment Share on other sites More sharing options...
carl Posted October 5, 2010 Author Share Posted October 5, 2010 No one has any idea? Quote Link to comment Share on other sites More sharing options...
graham Posted October 5, 2010 Share Posted October 5, 2010 I submitted this bug a while ago but it has yet to be fixed, though I'm not certain how well a fix will work with old versions anyway. Basically you are out of luck. Depending on the complexity of your scene you could open it up in 503 and copy/paste nodes to an open session of 469. You could also look opscript to output your scene and recreate it in 469. Quote Link to comment Share on other sites More sharing options...
carl Posted October 7, 2010 Author Share Posted October 7, 2010 I submitted this bug a while ago but it has yet to be fixed, though I'm not certain how well a fix will work with old versions anyway. Basically you are out of luck. Depending on the complexity of your scene you could open it up in 503 and copy/paste nodes to an open session of 469. You could also look opscript to output your scene and recreate it in 469. Thank you graham, I will definitely try that Quote Link to comment Share on other sites More sharing options...
