MsX Posted October 1, 2010 Share Posted October 1, 2010 Hey guys... I'm completely new to Houdini, and I was wondering how you can duplicate an object along a curve? Thanks in advance Quote Link to comment Share on other sites More sharing options...
pclaes Posted October 1, 2010 Share Posted October 1, 2010 (edited) Like yourself there are many others new to houdini that want to do this. As this is a common thing to try and do, I would recommend performing a search here on odforce or on sidefx for: "copy" "curve" There is actually a tutorial on the sidefx website that shows you how to do this: http://www.sidefx.com/index.php?option=com_content&task=view&id=1242&Itemid=255 Most likely this is using it as well: http://cg.tutsplus.com/tutorials/houdini/3d_cg_houdini_sidefx_modeling_asset_vfx_workflow_autofence1/ Edited October 1, 2010 by pclaes Quote Link to comment Share on other sites More sharing options...
tony Posted October 1, 2010 Share Posted October 1, 2010 Check out this file: duplicateAlongCurve.hip It copies the object to every point on the curve, so if you want to change the amount of objects, just put a resample in after the curve1 node. Cheers Tony Quote Link to comment Share on other sites More sharing options...
MsX Posted October 1, 2010 Author Share Posted October 1, 2010 Thanks a lot guys Quote Link to comment Share on other sites More sharing options...
