Houdini with Renderpal
borisb2
Hi.
I'm trying to setup Renderpal with Houdini. Unfortunately I didn't found any tutorial or help about setting up executables or renderers in the render management window in Renderpal.
Do I really have to create an ifd-file for every scene (.hip-file) that I want to render? The Houdini-help is mentioning that you also can directly render .hip-files from command-line using "hrender". But on Windows you have to use something like cygwin-environment (Unix).
Has anybody used Renderpal with Houdini?
I managed to output the ifd-file from the mantra-node in Houdini. But only the last frame from the sequence was rendered. Of course I could output now one ifd-file for every frame and import that in RenderPal but that can't be the idea????
maybe I should start in getting a propper ifd-file and render that from command-line as a test?
Thanks for any help.
Edited by borisb2
Normally one frame per ifd. One command triggers the render of one frame using the ifd file for that frame. I know with rib files you can render multiple frames in one rib, but not sure if you can do that with ifd. It wouldn't be that efficient I think, as all that geometry would have to be written per frame in that one file. I would get bloated quickly unless you are using procedurals to render.
hmm .. but there must be a way to render a sequence with Renderpal? ;)
Thanks anyway
Well, you could make the command yourself.
like a little for loop in shell or python. I don't know what renderpal accepts.
Have a look here:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=11494
or this one:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=13191&highlight=hrender
in shell:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=14151&highlight=hrender
more:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=16761
I guess you are on windows, I have only used it with ifds personally, but I would think this is what you need:
hrender -e -f 4 39 -v -d your_ROP c:/path_to_your_file/file_with_no_spaces_in_name.hip
You'll need to execute that in the shell that comes with houdini (a cshell with houdini environment set up).
  • 1 month later...
