wavesmack Posted October 13, 2010 Share Posted October 13, 2010 HOUDINI | Building Generation High Definition Training Videos for the Visual Effects Industry Princeton, NJ (October 11th, 2010) – cmiVFX launches its latest training video in HOUDINI, called Building Generation. HOUDINI – Building Generation http://www.cmivfx.com/productpages/product.aspx?name=Houdini_Building_Generation Introduction Buying expensive software to generate cities? Well now you can create buildings right inside of Houdini. Do this interactively and customize the buildings via Assets for new and unique structures. This video will teach you how to create a PROCEDURAL and CUSTOMIZABLE building. Not only you will have the option to change the pre-existing set of parameters, but most importantly you can yourself create, remove or modify the assets which are the actual bricks that constitute the building, ranging from doors to balconies to anything you can think of, they will be directly taken into account and parameters automatically created for them… So that you will be able to modify the general building parameters and the parameters for YOUR assets as well to customize even more the result you have. You can even build asset libraries and with a few clicks switch from one library to another to get a whole new result. If you're going to be in this industry.... this is the video that you want in your library. Building the outline shape The first step in the process is to get the outer outline shape of the building. That can be done in many ways. You’re going to learn in this part how to do that the direct way and then how to replace that with syntax based system to make the outline shape generation the best and most flexible it can be. For the syntax based method a mix between python coding and basic workflow will allow us to get the desired result. While a human can control the result, when the process is automated undesired results may happen, unless some special conditions are added to the input parameters, which will be discussed as well. Façade creation After creating the outline shape of the building, the dummy grid facades that were used, have to be replaced with real facades. To build the real facades there is a lot of possibilities. Some of those possibilities will be explored, among which some are simpler than others and can serve to be used in simple situations where not much complexity is needed, and the last one on which the choice is set for the final building is more complex than all the other methods but is far more flexible and controllable. Here as well python code will be used to participate as a part in a hole in the façade creation. A very important aspect of the building is defined here, which is the customizability of the components of the building, so you’re going to see how the assets system works and how much power, control and flexibility it gives to our building. And at the end you will see how all that adds up to replace the grid facades with the real facades and approach the final shape. Floor separators, roof and colors At this point the building is a hollow shape without a roof, so this part will walk you through the creation of the floors separators which will form the ground for each one of the floors, and using almost the same techniques the roof is going to be created. Sometimes getting the desired result becomes a little tricky, and colors can help you greatly while debugging, this is why you’re going to see how to add some colors to your building based on many parameters such as colorizing per floor, per façade or per wall. Building parameters Now that the building is all done, comes the parameters turn. The parameters are a very important aspect of the building, and they can be divided into two big families, the first is the standard building parameters that are there all the time, and the second family is the parameters that are generated or removed on the fly whenever you create or remove an asset of your building assets folder. Some of the parameters need to generate an event that calls a callback script that will update the building and depending on the scenario this can be tricky so you’re going to see a couple of methods of how to do that and how to implement conditions into that as well. And of course using python code you’re going to see how to generate the corresponding assets parameters on the fly. Practice The last part of our journey will be more like an exercise, where you will be trying to use the building, by seeing how to add assets, how to use their parameters to control their use throughout the building. Like any other system, this system has some Dos and Donts that will be discussed here. And at the end we're going to talk briefly about creating multiple different copies of our building using a copy node and stamp functions. About the cmiMentor Georges Nakhle is 26 years old, Lebanese, and has a master’s degree in mechanical engineering. He has a wide artistic and scientific knowledge, he began his art steps with traditional painting and sculpting then gained a diploma in dramatic monologue (acting -singing), he has worked as a writer and performer in radio and TV. Combining arts and science led him to CG, so he mastered many 3D tools such as Maya and Houdini, he's also a programmer so he's currently working for Dassault-Systemes in Paris-France and he had also worked in combination between Dassault-Systemes and mental images the makers of mental-ray. He is very picky about the details and he believes that every small detail contributes to the finished product. Subscriptions – ACT NOW! Gain access to Every New Release and the Entire cmiLibrary with cmiSubscription plan. Obtain the latest releases automatically and special features from cmiVFX. For more information on our subscriptions: http://www.cmivfx.com/productpages/product.aspx?name=Subscriptions_And_Pricing cmiVFX on TWITTER: Follow us on twitter and receive news, updates and special offers for our twitter fan base. http://www.twitter.com/cmivfx About cmiVFX cmiVFX is the leader in High Definition Video Training for the Visual Effects Community. Register for FREE and receive hours of FREE content at the cmiVFX Video-on-Demand Player. For additional information about cmiVFX, visit www.cmivfx.com . © 2010 cmiVFX | cmiStudios. All rights reserved. Quote Link to comment Share on other sites More sharing options...
