hopbin9 Posted October 30, 2010 Share Posted October 30, 2010 Hi, Another noob question, sorry but I can't find this in the manual. I have a sphere emitting particles as it travels. The particles have a velocity of zero so they hold in space. Problem is there are gaps spacing the particles apart cause they are created at each frame. I need to create particles smoothly between frames as well. I tried using the constant impulse birth, constant birth and increasing the oversampling on the POP network, but nothing seemed to fix it. Any ideas? Thanks, Quote Link to comment Share on other sites More sharing options...
Netvudu Posted October 30, 2010 Share Posted October 30, 2010 (edited) yep, this is a common one. Add the Timeblend SOP to the geometry you´re going to input into POPs. That should fix it. It surprises me though that it happened to you with a moving sphere, and oversampling didn´t fix it, at least partially. This tends to happen to me with geometry sequences. Edited October 30, 2010 by Netvudu Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted October 30, 2010 Author Share Posted October 30, 2010 Thanks you, I'll give it a try. Sorry, it wasn't a sphere it was a circle. I was emitting from the edges so the problem was very apparent. Quote Link to comment Share on other sites More sharing options...
Klockworks Posted October 31, 2010 Share Posted October 31, 2010 What was your oversampling set at? Quote Link to comment Share on other sites More sharing options...
