Klockworks Posted October 30, 2010 Share Posted October 30, 2010 Hi, I am working on a project that has heavy interaction between POPs and DOPs. I want to keep them separate to be able to art direct their movement more easily. My question is: Is there an alternative to bringing in particles into a DOP context over a POP Solver? I have tried using a SOP Geo looking at a frame sequence in SOPs, but with set Initial on the frames of particles just add up and never die, and if I do Set Always the cook time is triple that of a POP solver. It isn't the most important thing in the world but I am trying to add in efficiency wherever I can within this effect. Any help would be wonderful. Quote Link to comment Share on other sites More sharing options...
Klockworks Posted November 11, 2010 Author Share Posted November 11, 2010 So I figured out a solution to my problem. I don't know why sopGeo was taking so long to cook from my original post, but I ended up looking in a few of the objects(RBD & Particle specifically) for a common method and removing what I didn't need from them. Attached is a simple example file with my solution. particleFile.hip Quote Link to comment Share on other sites More sharing options...
