kni8_2k Posted November 1, 2010 Share Posted November 1, 2010 (edited) Hi there, I am trying to run some system commands on my mantra Rop during the pre-render scripts. I wanted to embed the name of the file that is being written out in to some system command that runs an operation on the file. ie: we have version controlling of files, and I would like to have the checkout/editing of that file be automatically handled by the rop. but I cannot get it to do the run the command properly. I think its the way I'm trying to reference the channel which has the name in it. `system("cmd /c vesionControler.exe edit chs('/out/Render/vm_picture')")` when I replace the chs with the full expanded path of the file it works, but I can't access the parameter live. and I guess the mistake I'm making is probably sooo simple that I can't find any documentation about the correct syntax for accessing parameters from with in strings. any help would be appreciated. Thank you. Ali. copy of same question on sidefx forum : http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=20968 Edited November 1, 2010 by kni8_2k Quote Link to comment Share on other sites More sharing options...
kni8_2k Posted November 1, 2010 Author Share Posted November 1, 2010 Hi there, I am trying to run some system commands on my mantra Rop during the pre-render scripts. I wanted to embed the name of the file that is being written out in to some system command that runs an operation on the file. ie: we have version controlling of files, and I would like to have the checkout/editing of that file be automatically handled by the rop. but I cannot get it to do the run the command properly. I think its the way I'm trying to reference the channel which has the name in it. `system("cmd /c vesionControler.exe edit chs('/out/Render/vm_picture')")` when I replace the chs with the full expanded path of the file it works, but I can't access the parameter live. and I guess the mistake I'm making is probably sooo simple that I can't find any documentation about the correct syntax for accessing parameters from with in strings. any help would be appreciated. Thank you. Ali. copy of same question on sidefx forum : http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=20968 sorry guys this should be in the scripts section. Reposting to scripts... cheers, a. Quote Link to comment Share on other sites More sharing options...
