jfhtx Posted November 8, 2010 Share Posted November 8, 2010 Hello, I found a hip file about intersection but I cannot retrieve that one here. Nevertheless it is called “curveIntersect.hip”. It finds all points’ intersections on ONE curve. The author included also the method to Select the intersecting pair you want to focus. As I’m not having a deep knowledge of Houdini, I’m asking that question: 1) How to manipulate the points colored in RED to avoid the overlapping of the tube. I join the modified file as the example and a picture for the intersection. Again, I apologize for not giving the proper link of the author of that hip file. Thank you to help me resolving that problem. curveIntersect_idea.hipnc Quote Link to comment Share on other sites More sharing options...
jfhtx Posted November 18, 2010 Author Share Posted November 18, 2010 Hello, I found a hip file about intersection but I cannot retrieve that one here. Nevertheless it is called “curveIntersect.hip”. It finds all points’ intersections on ONE curve. The author included also the method to Select the intersecting pair you want to focus. As I’m not having a deep knowledge of Houdini, I’m asking that question: 1) How to manipulate the points colored in RED to avoid the overlapping of the tube. I join the modified file as the example and a picture for the intersection. Again, I apologize for not giving the proper link of the author of that hip file. Thank you to help me resolving that problem. Ok ,I found a good solution with the WIRE OBJECT but when I have let says 500 wires the sim is going slow. So I was playing with the ray sop and the lift param. I just don't know how to get reed of the extra straight line. I hope that someone can improve that intersection problem so it will be nice for the community. Thanks.curveIntersect1.hipnc Quote Link to comment Share on other sites More sharing options...
