MENOZ Posted November 8, 2010 Share Posted November 8, 2010 reading the help dopfield(dop, objectSpec, subDataName, recordType, recordNum, fieldName) what is the recordNum? Quote Link to comment Share on other sites More sharing options...
graham Posted November 8, 2010 Share Posted November 8, 2010 It's to specify the individual record when the data that has more than 1 record available. An example is Impact data. When impacts are happening there can be more than one, so you'll see a list of them. recordNum allows you to pick which one you are interested in. Typically for Impacts you'd use dopnumrecords() to create a number of points equal to the number of records then use stamp() to iterate over all the records to generate points for each. Quote Link to comment Share on other sites More sharing options...
