Tannins Posted November 19, 2010 Share Posted November 19, 2010 Back again with some more questions regarding absolute size of an object. I have a tire that was modelled and then transformed and scaled so that it matched the scale of the rest of the object. Now I am trying to do a realistic rotation of the tire from the speed of the object - but I am not sure how to get the absolute size of the object. I know that I can take the original size and multiply it by the scale etc - but is there an easier way to do this (ie. if I have multiple scales applied or edits etc)? Anyone come across this before? Quote Link to comment Share on other sites More sharing options...
Tannins Posted November 19, 2010 Author Share Posted November 19, 2010 Also I've noticed when I try to rotate the tire it does not rotate based on the middle of the object. So when I rotate on the x-axis it rotates but it also moves away from the position that it is supposed to be in. How do I specify just to rotate around the centre of the tire? Quote Link to comment Share on other sites More sharing options...
Macha Posted November 20, 2010 Share Posted November 20, 2010 How do I specify just to rotate around the centre of the tire? Try $CEX $CEY and $CEZ as pivot center. Quote Link to comment Share on other sites More sharing options...
